stock smic.. will this piping work?
BoredOutaMyMind
304
May 3, 2004
Niceville, Florida
looks like it might work, but it would be a tight fit under the fuse box, the 90* piece looks to be alittle tall compared to the greddy pieces, also on the 2nd pic, you can see the 90 is not bent, more like 2 piece of cut pipe that have been welded (or atleadst thats what I see) to creat a MAJOR corner, thus major restriction. Check local DSMers for people who have upgraded to short route FMIC and buy their old upper lower IC pipe, and get a BOV to mate. It may be used, but you know it worked and would cost less than what these ebay ads are going for.
Does anyone else have an opinion on this? im mainly worried about it not fitting and that 90 degree bend... i simply want to order this and get it done with so i can turn up the boost, without my 2g bov exploding... however, if anyone else has hard IC piping that will fit a stock 2g smic and is flanged for a greddy type s, i wouldnt mind buying it :)
Ill just toss this out there for you and you can take it how you want. So many people just want to get it done and do it half ass. Then they have to do it over again the right way and it cost more money, time, and headaches in the long run. If you buy the rightr parts once you will be done and happy.
Most the time those kits wont fit very well. They are usually just made by some guy in his garage, I can tell by that 90* bend. If you do it right you only do it once.
