will my setup work efficiantly
6bolt2gdsm
244
Feb 11, 2008
burlington, West Virginia
My question is if this will work efficiantly with what I have. This is a different car than in my profile so nothin in there is the same. I have a dnp manifold with external 38mm wastegate mounted to a pte6152e, and obviously a fmic with 2.5" intercooler piping. I have an afc and a wideband with fic 650cc injectors. Will i be able to run this setup okay with what i have to tune with or should i ditch the afc and go with dsm link.
Thanks,
Brent
You diffently need something to log with. The 650 injectors are about max you can tune with an afc with. If you can afford an eprom and link go for it. If you don't I would recommend palm tuning; tmo or something of that nature.
With that large a turbo, you might want to consider some larger injectors, you are going to be making those 650s work way too hard. I run 680s comfortably on my b16g. And for such a heavy flowing set-up, something more accurate than an SAFC would help. Link is one route to go.
So with that type of setup would i still need an afc or something to "fine" tune with?
