Will a small 16g fit into the 14b turbine housing?
tom04841
611
6
Jul 21, 2004
Rockland, Maine
I just bought a used small 16g but there is a broken stud that i cant get out and really don't want to spend the time to drill it and retap, and run the risk of snapping some turbo to manifold bolts if i don't have too.
Can i just take off the v-band and swap the center sections and compressor housings? I know the 7cm tubine housing is less restrictive, but i am looking for ease of install. and the turbine housing has a crack in it anyway.
Will this work?
i would, but i am already selling the 14b to a buddy with a 2g. He kind of needs the turbine housing...LOL
So you are POSITIVE it will fit?
the stock 14b turbine wheel is the same as the small 16g turbine wheel
Yes, it will work for sure.
I'll trade you a ported 6cm housing for the 7cm, i'll take care of shipping.
its cracked, but sure if you want to cover the shipping from me to you. I would need you to send yours first tho....i am swapping it this weekend and told my buddy i would have it to him by tuesday.
I've replaced the cracked housing on my 14B with a new ported one from a 16G. When I sold my 14B, I kept the housing and put that on a used 16G and put the unported housing on my 14B and sold that. They're readily interchangeable.
Cool....thats what i needed to know. What psi is the s16g capable of....i have w/i so i don't mind if it is a little out of the efficiency rance just a bit
