JusMX141
Moderator
- 15,147
- 1,292
- Dec 13, 2005
Greensburg,
Pennsylvania
'zatrite?The wastegate hole is the same size on an hy as an hx. I have them side by side at home.
9cm2 HY35 left, 12cm2 HX35 right....both from the same generation of Dodge truck as noted by the studs present in the rear mounting holes on the manifold flange (no other HX35 application utilizes two studs in the manifold flange):
Perhaps I exaggerated a bit on the size of the HX35's wastegate port...it's actually closer to the size of a penny than a dime. The HY35 has about a stock DSM-sized wastegate flapper and port.
