Twin Scroll manifold wastegate question
apedog
158
May 6, 2009
Lewisberry, Pennsylvania
So im actually in the beginning process of getting a ts t3 exhaust manifold welded up. I know you need a wastegate for each side of the manifold but I was thinking today...What if you can somehow weld a wastegate to the compressor housing side of the turbo:hmm: I was just thinking it could control boost right at the turbo, so at the collector when exhaust comes through its about an equal pulse?
^ To do it correctly yes, but it WILL work. However, if you do it correctly, your spool time, and boost control will be better.
Even if you gate on the turbine housing on a twin scroll turbo, it still needs to be divided all the way up to the valve(s). See an EVO8/9 turbine housing for an example.
Yeah I saw that. Didnt Mr. peepers end up doing that or was it somebody else? I saw someone with one wastegate but it was divided up to it. I just dont want to buy two wastegates :(
But I will if I HAVE too:D
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
