why fuel cut
woomer
113
Dec 18, 2006
huntingdon, Pennsylvania
ok i have a 93 eagle talon -the car was originaly a automatic..changed over to 5speed which i did myself and i changed all the basic things ......i now have a fuel cut off problem arond 5500 it hits a wall.no fuel for a split second ..i changed computos in the car 2x once iused my computor out of the original standard car ....got the dreaded shut off.so i switch the auto computor into the car ..ran great for a few hrs .......now my fuel cut off is back .this car is not a turbo so im sure its not boost leak .any suggestions ??.need help very very fast
cmon every one throw some things at me here .........ill check and recheck any thinng you guys have to offer me on input
Did you put a 14b on in replacement of the stock auto turbo. If so your stock injectors are only 390cc. How much boost are you running???
im using the stock ecus and injectors -all i did was change a automatic car over to a standard with using my old stadard car ------there was no motor in the automatic car so i used mine
    • Sdcryan1
