Whining sound from the engine
glennsanity
32
Mar 20, 2012
belleville, New Jersey
hi guys i really need your help here. my 97 eclipse gs non turbo is making a whining noise from the engine, a mechanic told me that it was the power steering pump buy when i had it changed, the whining noise didn't go away. so if any of you guys had the same problem just please let me know how to fix it. Thank you.
Video would benefit us more than anything?
Could be a lot of different reasons, starting with belts. When was the last time you or they were changed out? Many other possible opinions are alternator bearing, tension bearing, you will have to try little different things. Try using a bar of soap on each belt and if the noise cuts out, then you now know where & what accs. belt or etc the problem is on.
thanks! I will post a video clip later on.. I had my timing done 6 months ago.. so are there any ways or steps on how to diagnose where the problem is coming from.?
you can use a bar of soap, if you think it is coming from the accessory belts. If you think it is coming from the inner timing cover, then you will need to either tear it down or you can get a car stethoscope and get to work....It is hard to say with actually being in front of the car.....
no, the sound started even before the ps pump were replaced. We thought it was the ps pump so we replaced it but it didnt go away. I will try that bar or soap and keep you upadated.
Here's the video clip of it. If you have any idea just let me know.. Thanks
yeah i will try doing that.. Thanks a lot!
Will it turn on without the alternator belt though?
Have you tried to remove one belt at a time? What does the timing belt look like? Sounds like something is rubbing against something, When you look at your timing belt through the inspection cover, move the timing cover either forward or backward and see if it isn't rubbing against it.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
