which way should this clutch face
jaredgsx
342
8
Mar 9, 2005
evansville, Indiana
I am putting in a new clutch after my tranny has just been rebuilt, i was not paying attention when i took the old clutch off to see which way it should face.
Should this side be facing the pressure plate?
also i would like to know if i am understanding this correctly.
When you hit the clutch pedal, it makes the salve clinder push the clutch fork foward, which pushes the throwout bearing onto the pressure plate/clutch disk, and pushes them foward enough so that the imput shaft is not engaged with them anymore so you can shift correct?
ok well here is a better pic
the one on thr right should be facing the pressure plate and the one on the left should be facing the flywheel
BINGO!
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
