Which turbo sholud go where??
greyspyder117
373
Oct 13, 2008
Bronx, New York
Whats up guys? I have a 97 gst spyder with all the mods i have in my profile plus a couple other things that need to be installed. But i do have them. Like SB'S front mount, injectors 550's, 255 fuel pump, afpr,. Then i have a 91 gsx with very lil mods. Intercooler piping, intake pipe, boost controller, and gauge. I blew the engine on the gsx and had it rebuilt. I have two brand new evo 3's one ported and one not which one should go where? I consider the spyder my baby if that helps. I have 2 ex manifold and 2 o2 housing both evo3 but not ported. So what do you guys think where should i put the ported one? :hmm:
i would recommend putting the ported one along with all the other mods on your gsx... but hey, i think i am just partial to AWD cars...??
Well if you port the other one you'll have 2 ported turbos and then both cars will be happy.
Port your 2g manifold and put the ported one on the 2g spyder. Buy an evo3 manifold and seal ring and put the non-ported turbo on the gsx with an ev3 exhaust manifold. It will flow the same and velocity at the collector will be higher because the collector is a smaller volume. Spool should be actually faster by doing it right. And again noone has see a flow difference between running a ported 16g setup vs. a seal ring and correct manifold on their 16g setup.
