Which Timing Belt Components for 6 Bolt with 2G Head?
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
I have a 6 bolt block and a 2g head. Which timing belt and tensioner should I get. Through th search, I found that there is just one belt now but I just wanted to verify.
ok, thats what I thought. Im also assuming the 90-92 tensioner as opposed to the 92-94 one.
You assume correctly; because 92-94 is a 7-bolt it uses a different tensioner. And yes, they all use the same timing belt.
6-bolts get literally 6-bolt everything timing-side wise when paired with a 2g head.
You also need a 6-bolt crank trigger plate to time your motor correctly
