Timing belt components
94lt1
Sep 18, 2011
Wheaton, Illinois
Hi guys, I'm swapping a 6 bolt into my 2g and am going to freshen up the motor. I definitely plan on buying OEM Mitsu parts but I'm curious if there are any differences in the parts between different years of the 6 bolt? For example, if a 91 water pump is slightly different (would still fit of course) then say a 92?
Also, the only site I've found to get OEM parts is oemmitsubishiparts.com, is there a vendor around here that sells OEM parts or another website I could check out?
Thanks for the help! :thumb:
I recommend Extreme PSI, JNZ and Maperformance for any parts period. Extreme PSI is my first choice if you order earlier in the day and your parts is in stock they will have it ship out the same day.
I buy everything from streettunedmotorsports.com if they have it. prices are decent and if there are any slightly over i still buy from them to support the shop that carries all the crap on stock that ill ever need.
