Name these Timing Components!
Atuca
Supporting Member
1,145
303
Jan 6, 2007
Central Valley, California
Using the format:
1. <name>
2. <name>
3...
Can you name these parts for me? I got part numbers for ordering a new set for a complete motor, but I think I have half of them laying here. I do know the names of all of them but only a handful I could actually match the name I got written down to the physical part heh :D.
Since I couldn't find a picture reference, can someone just spell it out for a n00b like me?
Thanks!
pics!
from SnowBorder714:
1. Trigger plate
2. Crank sprocket
3. Idler pulley
4. Crankshaft balancer sprocket
5. Balance shaft sprocket
6. Tensioner pulley
7. Balance shaft
8. Oil pump sprocket (upside down)
9. Tensioner arm washer (Chris called this one)
10. Harmonic dampener
11. Water pump pulley (for alternator)
12. Water pump pulley (for power steering)
13. Balance shaft spacer
14. A/C belt tensioner
1. Trigger plate
2. Crank sprocket
3. Idler pulley
6. Tensioner pulley
7. Balance shaft
And I hope you know the water pump and timing belt tensioner.
I was going to try but I was just going to give you a generic name to them, which I think you say you already know.
Maybe CAPS will help?
CAPS
I downloaded caps yesterday.. and it won't run on vista 64.
<. insert vista compatibility phail here .>
Thanks though for the together picture! Lots of parts to order for a new motor heh.
edit!! O wow... ONLINE CAPS!! I AM SAVED. thanks man!
1. Trigger plate. Goes in between #4 and #2 on the crank
2. Pully for the timing belt on the crank. Goes on after #1
3. Idler pully
4. Pully for the Balance shaft belt. Goes on the crank first
5. Other gear for the Balance Shaft belt. Bolts the front cover/oil pump
6. Timing belt tensioner pully(Should have two tiny holes in it to apply tension)
7. Balance Shaft Belt tensioner
8. Oil pump Drive gear
9. Not sure on this one
10. Crank Shaft Pulley
11/12 Water Pump and water pump pully
13. Not sure abou this one either
14. Pully/bracket for the A/C belt.
Yes sir. I always use this thing when Im in a bind.
Snowboarder714 is right with everything, and #9 is the washer that holds Tensioner Arm to the Motor Mount!
#13 is actually under the Balance Shaft Sprocket and seals on the inner lip of the balance shaft seal in the front case.
well I have the 1g motor mount there in the same box which is probably the reason I have the washer in the same box when collecting these parts. Why I don't have the tensioner arm is beyond me, but its only 30 bucks to get an oem new one.
Thanks for all the help guys. I just want to order all my new parts and its been taking me weeks to get a list together of what I need.
Just to clarify: You do not need to replace all of these parts. If the part is broken, then replace it obviously but #3,6,7 (the tensioners and idler) and hydraulic tensioner (that has no number, pic right) are the ones you have to replace.
