name these wires
greathuskie
2,666
4
Sep 10, 2002
Hollywood, Florida
there is a few unused up by the old oil pressure gauge area, which most were from the stock gauge, but also some back by teh intake mani which i dont know what they are, they are soldered together, and sometimes when i touched them i heard like a motor running from the left top side of the engine bay, it was strange. pictures:
also if anyone can tell me why my car wont work after alternator install, please let me know..
do you have a 6bolt swap? looks like the connectors for you crank position sensor and your cam position sensor
Car wont start at all after alt? crank anything?
its probably where they wired in the cas. my suggestion it to get some electrical tape or heat shrink on those fast. when you touch them that little motor you hear is the iac adjusting
do they need to be physically plugged in to anything, or just taped up and the cords sitting there is fine?
no they shouldn't need plugged in with the 6 bolt swap the cas takes over function for both those sensors. just tape up any exposed wires separately and zip tie them away from you tbelt or any other moving objects. Make sure you have a good connection on all the wires first.
