which Holset for 2.3 evo ?
stunt2
79
Oct 18, 2010
New Castle, Delaware
Hey guys,
this site has lots of info and knowledgeable people about holset turbos, so reccomend me which way to go -
car is evo4, 2.3 forged 9:1 comp. engine with S2 cams. + all supporting mods. I'm not seeking for insane hp levels, just need good flat powerband and quick spool. with nice top end (which I don't have with evo9 turbo). will be tuned on 93pump only
as I guess, 7blade HX35 with TS 12cm^2 T3 housing will suit best my setup end needs. what do you recommend ?
car is mainly daily driver and weekend time attack/autoX/drag car
yes, I'll sacrifice bit top end power for quick spool...
is that 2.0 ? where does it hit full boost ?
p.s. what can you guys say about H1C/WH1C ?
The turbo you just listed is PERFECT for your application when used with a twin-scroll manifold.
WH1C's are inferior to 7-blade HX35's for two reasons:
1: Inferior thrust bearing design that doesn't take well to high boost and needs to be upgraded (though there are upgraded ones on the market).
2. Larger, less efficient 8-blade compressor wheel that's slightly better at low boost, but gets killed in response and ultimate power by the 7-blade.
Throw in a Hy-35
Undivided t3 9cm2 housing(faster spool), physically smaller than then HX (evo's lack the space) and guys still touch 10's on them.
RWD4G63
thanks for detailed answer
Sp1kE
undivided T3 would be definately less hassle for me but loosing TS how good will it be spool wise even with 9cm housing ? or flow wise
ok, so got it, H1C/WH1C are aout of the game.
have to make choice between HX or HY 35
are there 7blade HY35's as well ?
RWD4G63
Sp1kE
All HY35's are 7-blade. I like their compressor covers better, but they will not match a twin-scroll HX35 for spool. Not a chance.
Take the 12cm housing any day over the 9cm especially with TS and a 2.3l. Damn, a 40 w TS would really kick ass too. But the stock housing is pretty large i believe
Even with a 12cm housing machined for an HX40, I don't think the spool would be where he wants it.
ok guys, roger that :thumb:
what power levels can I expect on this setup ? (93oct)
You should be able to push over 400whp on pump.
7blade HX35 in a 12cm T/S is what you need, I'm running that same thing but on an 8.3:1 2.0 motor and i am boosting 15psi at 4K on a low power tune. on your motor this turbo should spool up quite a bit faster, id guess at least at 3.5k between the hightr comp and more displacement. and the 7 blade HX35 will feel like a your stock turbo on crack! it hits so darn hard.
also look down \/ here
