Which coilovers for drag racing?
LocknessMonster
113
Jun 19, 2007
Saint James, New York
I would like to get coilovers for my car and was wondering what you guys were using for your drag setups. Thanks
theres a bunch of different setups out there, the only thing that limits most is cost. a coil over setup is more for autocross so you can set the ride height... a more "drag race" setup would be a shock and spring. the setup ive been running the last few years are tokico 5 way adj. gas shocks with the eibach sportline springs. i love the shocks because when i go down to the track i can put them at their max stiffness and they let my wheels dig, then i turn them down and my girlfriend doesn't puke on the ride back to the house. i would, however, not buy the eibach sportlines if i were to do it again because it dropped my front end WAY WAY too much (but you've got a 1g and to slam those things to close to the ground would require an elephant sitting on your hood) anyway, i think a good dd/track setup for a reasonable price would be...
tokico 5 way adjustables, eibach pro street springs, an engalls camber kit (cause your alignments going to be way off), and a good alignment, all this for just under a $800 if you can do the installs yourself and you'll def. gain a noticeable difference in traction. :thumb:
:dsm:
Koni Yellows and find a spring that doesn't sag (seems to be impossible today). Maybe a set of Ground Control sleeves.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
