Where to find differential shim kit?
The front diff shim kit has not been around for ages. They are only available as singular shims in limited availability.
The speedo sensor gear that gets heated up and pressed onto the differential is made by me now, replacing MD717879 -
The Quaife LSD differential is named either as QDH8B (25-spline axles) or QDH7B (27-spline axles) nowadays.
Part DescriptionPart NumberID NumberThickness (in)
Shim - Input ShaftMN1681470.440.0173
Shim - Input ShaftMN1681480.480.0189
Shim - Input ShaftMN1681490.520.0205
Shim - Input ShaftMN1681500.560.0220
Shim - Input ShaftMN1681510.600.0236
Shim - Input ShaftMN1681520.640.0252
Shim - Input ShaftMD7276590.650.0256
Shim - Input ShaftMN1681530.680.0268
Shim - Input ShaftMN1681540.720.0283
Shim - Input ShaftMD7276600.740.0291
Shim - Input ShaftMN1681550.760.0299
Shim - Input ShaftMN1681560.800.0315
Shim - Input ShaftMD727661800.0315
Shim - Input ShaftMD720937830.0327
Shim - Input ShaftMN1681570.840.0331
Shim - Input ShaftMD720938860.0338
Shim - Input ShaftMN1681580.880.0346
Shim - Input ShaftMD720939890.0350
Shim - Input ShaftMD720940920.0362
Shim - Input ShaftMN1681590.920.0362
Shim - Input ShaftMD720941950.0374
Shim - Input ShaftMN1681600.960.0378
Shim - Input ShaftMD720942980.0386
Shim - Input ShaftMN1681611.000.0394
Shim - Input ShaftMD72094310.0398
Shim - Input ShaftMD72094440.0409
Shim - Input ShaftMN1681621.040.0409
Shim - Input ShaftMD72094570.0421
Shim - Input ShaftMN1681631.080.0425
Shim - Input ShaftMD710454J0.0433
Shim - Input ShaftMN1681641.120.0441
Shim - Input ShaftMD700270D0.0445
Shim - Input ShaftMN1681651.160.0457
Shim - Input ShaftMD710455K0.0457
Shim - Input ShaftMD710456L0.0468
Shim - Input ShaftMN1681661.200.0472
Shim - Input ShaftMD700271G0.0480
Shim - Input ShaftMN1681671.240.0488
Shim - Input ShaftMD710457M0.0492
Shim - Input ShaftMN1681681.280.0504
Shim - Input ShaftMD710458N0.0504
Shim - Input ShaftMD706574E0.0516
Shim - Input ShaftMN1681691.320.0520
Shim - Input ShaftMD710459O0.0527
Shim - Input ShaftMN1681701.360.0535"
Shim - Input ShaftMD710460P0.0539
Shim - Input ShaftMN1681711.40.0551
Shim - Input ShaftMD7065731.40.0551
Shim - Input ShaftMD710461Q0.0563
Shim - Input ShaftMN1681721.440.0567
Shim - Input ShaftMD710462R0.0575
Shim - Input ShaftMN1681731.480.0583
Shim - Input ShaftMN1681741.520.0598
