1G wheel and tire size on lowered 1G
TBoneHere2Kill
Dec 30, 2021
Port Coquitlam, BC, Canada
Looking for a new set of wheel and tires for a summer setup and want to know what I can fit. Car is lowered on a set of coilovers, will adjust to fix the new wheel. Don't have a set size I'm looking for just what can fit without rolling fenders, stretching tire, or going full "Stance Nation" tilt wheel spec.
Fine with either 16" or 17" and would like as much of rubber as i can fit without rubbing or modifying/ grinding down suspension components
17x9 +35 square here. With camber plates guys have fit 255/40s on which is where I plan to go when my 225s burn off finally.
They barely clear the strut spring perches in the front - would be fine with coilovers. Had to clearance the trailing arms in the rear a little.
