What's used to water pipe lines?
95burgundyesi
816
9
Feb 8, 2006
Rockford, Illinois
I'm no longer running water to my turbo, and want to plug the two water line feeds on the turbo water pipe. Besides looping with a rubber line how are people plugging this.
Cut it off and weld shut, piece of hose with bolt clamped in it, or run a n/t pipe. These are the options I know of. I wouldnt recommend the hose with bolt. Id either get it welded or find a n/t pipe.
And, unfortunately, the 2G doesn't have the option of an N/T pipe here in the States without swapping to matching 1G equipment, so your pretty limited to whatever method you can come up with to plug up what you've got.
Our members across the pond, on the other hand, had a 2G N/T with the 4G63. It appears MD331600 is the part number for that though I am not 100% on it. Even then, where you might locate a source to track that down, I couldn't tell you.
Like this :) clean inside and out real good. I used barrel sanders then I folded or pinched them together than folded that over then welded shut. Painted to look pretty and have no leaks. If you have no fiav or heater lines you can cut that all off and close up to. That's what I did. And a finished pic :)
