What type valve seals/guides for BC Springs & Retainers
TurboSpider
223
17
Nov 2, 2015
York, Pennsylvania
So after posting this thread here (https://www.dsmtuners.com/threads/leaking-oil-from-exhaust-manifold.536100/#post-153822254) where I noticed there was oil in my exhaust manifold. I pulled the head and dropped it off at the machine shop to have it looked at. Its a 2g head that I have on a 6 bolt block. The head has BC springs and retainers put on from the person that built the engine prior to me. I forget the number on the retainers might of been 1000 or 100 or something like that. I can find out if it makes a difference.
I picked up a pair of BC 272 cams to have the machine shop install. The machine shop found some of the exhaust guides are out of spec which is probably the cause of my oil leaking into the exhaust manifold. I want to have them put new valve guides in and seals and was dead set on having them order Viton seals which from what I see on here, most people like to use those as they have higher heat resistance. However as I was ready to order them, I saw someone say in the reviews these are good seals if you have stock springs. Since I have upgraded springs/retainers I am curious what type of valve guide and seal everyone recommends?
Springs/retainers should not matter for the valve seals. I would recommend the BLUE Viton seals for both the intake and exhaust. That is what I use anyway and they seal very good. I have a set on a head with the same springs/retainers that you have and no issues at all and use them with all of my different camshafts/spring combo's.
