4G63Trevor
- 0
- Mar 18, 2004
Kelowna,
i am going to be making my own U/LICP. i was wondering what diameter pipe i should use. i am getting mandrel bent pips, as to get the best flow. i will be using the plate that bolts onto the throttle body, and just weld a new elbo on there, same with the outlet pipe on the turbo, use the bracke, and make my own elbo from there. i will eventually be getting a FMIC, but for now i want soe for the SMIC. Also, what is the outlet/inlet diameters of the stock 1G SMIC?? (plese specify outside diameter, or inside diameter if u give a size) as for the BOV, i will cut part of the stock hard pipe, and weld that on my pipe. if all goes well, i will meke a tech article for it, but all i need to know is what size of piping i should use for the upper and lower IC pipes
thank you so much
trevor
thank you so much
trevor
