What Should MyFuel Curve Be Set At??
trbotalon90
Mar 25, 2004
omaha, Nebraska
I know that when it comes to tuning a dsm, they are all different. I am always having problems getting the tuning right on my Super-AFC. Managing my fuel i have 255Walbro fuel pump, B&M FPR, and 560cc injectors. It seems that i am usually running a little rich at high throttle thus causing a popping in high RPM and a noticible loss of power. I was wondering if anyone has this close to same setup as me and could help me set my LO-throttle and my HI-throttle. I also am running a Big 16g and a Fmic. The temperature also takes in to effect which I am aware of and its currently been around 75 degrees.
Thanks
-Alex
I used to have a datalogger, but i accidentally ripped it out of the ECU and it never worked again. I never had it long enough to mess around with it and figure out how to use it.
No one can tell you how to tune your car, every car is different. You need to use a datalogger to find out what your car is doing and make adjustments from there.
