what should I set the fuel pressure to....
Four62ci
Apr 5, 2005
Clearfield, Utah
I have a 1990 GSX with a 2.5" cat back exhaust, tubular o2 housing, ported turbine housing, tubular exhaust manifold 255lph fuel pump and running 15 psi boost. Can someone tell me what fuel pressure I should set the AFPR to at idle with the vacuum hose attached. Also, at what point do I need to run a SAFC?
Set to 38psi without the vac line attached. A S-AFC is always a good idea as can "fine tune" specific RPM points to get additional milage/performance.
Thanks for the info.
