Resolved What piece is this
Mr_john
May 25, 2014
Kansas City, Missouri
Going through my harness taking out the ac lines and any unused wires and was wondering what this is for? Found the wiring diagram online but can't seem to find this guy. Thanks everyone also found one that was taped to the harness I'll take a pic tomorrow but it's one that was not being used
Can it be deleted I looked in the other wire tuck post and it's prob the one thing I haven't been able to find info on I'm getting rid of unnecessary wires and the car is in the process of being built and the only thing I find is a plug for it so I could only assume it's safe to follow back and remove? Thanks everyone also
Depends on what style injectors you plan to use, either low (as is stock in the originally equipped turbocharged DSMs) or high (non-turbo 4G63) impedance. If using low impedance injectors, you must keep the injector resistor pack. If using high impedance injectors, the resistor pack is not needed.
I plan on going big injector something flex fuel compatiable
