Mim
- 1
- Mar 20, 2011
Kansas City,
Missouri
Hey guys,
Still having issues with this 95 2.0 n/t.
Since the new head, it's been running horribly. If youve been following my posts you will see. NOW... yesterday it wouldn't start. I have a stripped screw hole for the thermostat housing so the thing sprays antifreeze all over the engine... still trying to figure that out without replacing the housing because that means removing alot..
ANYWAY, I got it started for a few min yesterday and it ran horribly. Idled funny and acted like it was missing or something. Parked it and it wouldnt start again. So I have been messing around with it. Threw code for failure with coil pack B, so I changed the thing. I think I fried my coil with the radiator fluid spraying everywhere.. I can see the tanish orangeish wire coming off the pack has a slight cut in it with exposed wire.... (once i replaced the coil pack, it stopped throwing the code)
After changing it swapping out wires, the car starts but runs like crap. White smoke out the exhaust and the pipe itself is shaking. To add to all of this wonderfullness spark plugs 1-3 are wet with gas but 4 is dry as a bone. I'm banging my head against a wall here. Please help!!
*Edit*
Now it is making a clicking noise that sounds like it is coming from the first cylinder right in front of the thermostat housing... I am going to put up a video here in a second.
*Edit*
there is no need to cheap on something you could pick up for 5bucks at a junkyard. Or are you saying the bolt that goes into the block is stripped?
