What kinda bov!!!!!!!!!!
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
looking at getting a new blow off valve. i have a greddy type s and the damn bolt stripped so i got a bad ass boost leak. need some help on getting a new for for not to much money around 150 but still sounds great. i like the pshhhhh sound loud. need some help??? :cool:
I also vote for the new greddy bov, I also have the type-s and want to switch to the rs! You should not have a problem stripping either the type-s or the rs. I am sure you won't need to tighten the bov that much unless your running some crazy boost. :thumb:
Does anyone know when the recirc. kit is coming out for the RS?
Middle of January I heard.
How the heck did you strip the adjuster screw? It moves very easily, or it should if it's working properly.
Actually i have heard that alot of people strip that screw, but just put in a better bolt in its place. The type rs looks great, but i like my turbo xs RFL. :D Hks has a new valve too, but i might look into an ARC, and see what pressure that valve can hold.
Don't get on my case bout venting, i have a mas setup. ;)
Just tap a larger bolt into it! I stripped mine after like 1 month use and had to do this. Everything is made out of cheap ass aluminum, so it wont be that hard to retap it. :thumb: :talon:
1st gen bov. cheapest. order from capital city mitsubishi in tallahassee. they give dsm discounts .... costs about 55 to 60 dollars i believe. Talk to charlie in parts.
Tyler
