what kind of ecu do i have?
What makes you think that your ECU is going bad? I mean what problems are you having with the car that makes you think it is the ECU?
giving me code when CEL is not on it says tps is bad and its misfiring
i replaced the tps and nothing happend and there is a funny smell from the exhaust so that is just my last solution
95-96 ecu will not work with your car.
There was ecu reflash/recall on the 99 ecus for misreading a TPS CEL, it was implemented on a customer complaint basis. The dealer may still be doing it.
Edit: From Mitsu docs.
99 ECLIPSE NAS 4G6 T/C (2WD)
Countermeasure for miss TPS failure judgement.
2003.5.1
Customer complaint basis
well when i unplug the Camshaft sensor it doesnt light up
so does anyone know the part # to the 99 ecu
