Resolved What is this line? "Image inside"
If you follow that hose, im almost positive it goes to your brake booster.
Solution
You both are correct.
Take a small screwdriver and put it under the hose to see if you can release it. Or make a slice in the line as short as possible and see if that would help you release it. Just make sure to cut off the section that was sliced so it will seal properly.
See if you can unthread the nipple that goes into the intake manifold. If you can get it off, put some teflon tape/paste on the threads and thread it back in.
Great help! I will give it a shot.
Kevin
