Resolved What is this line ?
ANGELRAY
89
7
Jan 29, 2024
Lubbock, Texas
Im changing my fuel injectors and all the other stuff my brother removed some lines to the fuel rail I’m not sure which one this goes to I’m not sure if it goes to my FPR it fits on it I have the OEM one
Solution
To post #1: yes, to the big nipple off of the fuel pressure regulator. This is the fuel return line, which carries unused fuel back to the tank.
To post #2: it is the solenoid you’ve marked as “2”. The other is the purge control solenoid valve.
I also don’t know which solenoid is the fuel pressure solenoid. I was trying the follow the tabooseedshop diagram
I got the solenoid marked as
1,2
Solution
  • Wanted 6 bolt NT water pipe
    • chrisman287
