Flash
- 3,359
- 14
- Nov 30, 2003
Highlands Ranch,
Colorado
I searched and read that the car will run fine. I'm trying to figure out why my monster tach won't get a signal. I did pull apart the engine and I have a very good idea that I forget to ground the power transistor when I installed a new intake manifold.
So if the power transistor is not grounded, will my mega tachometer not get a signal? Car still runs, and I can still log RPM on DSMLink. I'm using the same white wire off the ECU I used to get RPM signal for my AFC in the past.
