where is my power transistor?
im guessing the long plug by my coil pack? Im just not used to refering it as the power transistor if it is.
Where is it?
Its underneath your coil pack. Bolted to a gold plate. Its bolted to your intake manifold actually.
Hope that helps
If you have a JDM cyclone motor that did not come out of a vr4 (like mine) then you must purchase the 92 galant vr4 coil pack and transistor and remove them from their mounting plates and remount them to the old plates.
On these cars the transistor is on the fire wall side of the intake mainfold right on top and the coil pack is located under the intake manifold bolted to the head on the drivers side.
You will also need to modify the tacho interface to fit on the old mounting plate, you must add 2" of length to the white wire, the red and yellow will stretch to fit.
