What Exhaust Manifold?
If its tubular, make sure its over 1000 new. (you could buy cheaper used...) but ebay tubes will crap out eventually. They might be a good starting template if you have a ss or alum welder, so you can beef it up for cheap, but all the cracks you are going to have to fix, you will eventually nearing the price of $1000 in total expense.
Cast manifold are the ultimate in durability, Tubular in high end for most big turbos. Smaller turbos wont benefit as much from tubes...
The best most popular cast style is the FP race mani. Idk what that turbo is (lazy) but match the exhaust housing to the mani... t3 to t3, etc. while you have the opportunity. budget will decide your route for ya, tubular about $800+ cast is $300 max.
Have you considered the FP manifold? Reason I mentioned that being you didn't say if you T3 or bolt on. I was looking at that turbo as well, should be around the 60lbs per min sounds good to me.
