2G What do I need to pull a crank out of a junkyard? 4g64
ErikTande
Supporting Member
1,522
595
Dec 17, 2012
Centennial, Colorado
There's a 1996 GS spyder at my local junkyard that I want the crank out of for a future 2.3 build.
Can I pull the crank from under the car? Any special tools required? I want to be prepared before I go. A specific tool/socket list would be awesome.
A crank is only $36 from the junkyard. Worth it for me because I'm broke :cool:
If you'd quit doing awd burnouts tied to a pole, you'd have more money...:D :p ROFL
Are you trying to do a 7 bolt swap Eric? That is the wrong motor in that car and going backwards by most dsm standards.
You'll have to have the transmission removed, and if it's not, you're better off pulling the whole business out and removing the crank with the engine turned upside down on the ground after the trans gets separated.
I usually buy the whole motor, but in your case it makes sense to save yourself some rolling on the ground and get the whole thing yanked, then pull the crank out.
Btw, I feel the "broke" sentiment :thumb:
