What do I ground for Biss mode?
Did you even read the vfaq?
Here'd the cap off of the BISS - use a screwdriver to turn it in or out until you get the idle adjusted properly. Turn it gently, you don't want to bottom it out too hard, as it can screw up the air passage, and you don't want to turn it out all the way, have it pop out, and lose it, as they are hard to find (Mitsu part # is MD614948 and it's called, "Adjusting Screw, Throttle Body". You need a #5 O-ring (3/8x1/4x1/16, available at most hardware stores), now available as Mitsu part # MD608806. This goes right under the head of the screw in that valley that looks as if an O-ring should go there.).
So turn the BISS until the idle is correct, then shut the car off, remove the wire from the diagnostic plug, remove the timing plug jumper (reinstall the cap!), and start the engine. Let it idle for about 5 minutes, and see if the idle is normal.
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
