What did you do to your DSM today?
used the search button and researched some of its issues so i can fix them
yesterday I did a BLT and found my lower injector seals are leaking quite bad. also adjusted my tps and checked my isc.
also trying to sell my other talon again. hopefully I can so I will have more cash for the Eclipse LOL.
I think I ended up pushing coolant running 33psi and causing me to smoke consistantly. Probably going to be pulling the head soon so keep up for the update.
Put a indash flip out in her today and watched a movie with my wife with it. Kinda had a drive in movie experience in my garage!!LOL!! The first time my wife spent more than 15 minutes in my car.
I drilled a hole in my head on accident trying to get a broken fuel rail bolt out. Now im leaking a ton of oil:banghead:
Found out my compression is 155-155-65-155 from 1-4. Piston will most likely be coming out.
Made a boost leak tester. Checked for leaks, found none. Bypassed my wastegate and found my MBC to be only letting me boost 10psi. Took it apart cleaned it out, put it back together now back to 20psi.
finished fixing all the screwed up wiring i could find, pulled the throttle body to clean it. thought about deleteing more stuff. checked my pcv valve, and finally stared at it confused for about an hour
In the process of replacing the vlave cover gasket and Painted valve cover so waiting for it to dry and looking for other maintaince items to take care of before it goes on the road in a few weeks.....
Already done:
Tune
Correct timing and timing belt
14b install
Injector leak fixed
DP & Cutout install
Coming soon will be:
Changing out all drivetrain fluids
Replace tires
Got it back from my mechanic. It just passed inspection. Getting tags and registration tomorrow or wednesday :D
  • Wanted 1g WTB 1g eagle talon A-pillar trim.
    Looking to buy driver side A-pillar trim, with pods preferred.
    • Walnuts
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
