SixBolt_16G
- 1,076
- 1,067
- Nov 7, 2005
Illinois
In the middle of the engine block on the back side between it and the firewall. 2 bolts hold the bracket to the motor (and you can't see them because the bracket hides them) and 3 hold the mount to the chassis, at least on a 1g. It is similar on a 2g but the bracket may bolt to the transmission, I'm not sure on the 2g exact bolt location.
On a 2g car in the center in the front if you look down where the bell housing meets the block there is a bracket bolted to the transmission with 2 bolts.
In the rear if you see the speed sensor, the sensor actually goes through the bracket. There is three bolts that hold that to the transmission. It will be easier to see under the car.
Pretty much it’s the two “motor mounts” that are in front of the motor and behind the motor. The bolt you showed looks to be one that holds the brackets to the transmission.
While you’re under there might want to make sure your “crank walk” bolt is there and tight on the block. It’s the only one that threads into the transmission from the block side. It’s 12mm and kinda long. Seems your transmission bolts are coming loose.
Do you happen to have a unsprung clutch disc?
-Daniel.
Thanks, that helps a lot.. Ill go out there and check after these long, irrelevant meetings are over...
