curt-s
Supporting Member
- 3,544
- 2,405
- Dec 21, 2008
Winnipeg,
MB, Canada
Would you be willing to do more 1g tails?
At this time, there are a few things that are preventing me from doing this.
- I don't trust myself enough to bake/separate tail lights that are owned by somebody else. Due to the design of these, with lots of thin plastic trim, you end up deforming parts of it in the removal process.. mainly that long thin section that goes up over the body on top of the lights. You can fix, but it won't look new anymore.
- The set of lights probably ran between $500-600 (with the LEDs on an incredible eBay find of 600 for $100) for the pair, all electronics/supplies involved. This cost would obviously be paid by the customer, but the labour involved is around 40 hours. My total labour in this job is well over 100, but the rest was figuring stuff out and doing things for the first time ever. Let me say that my gf was NOT happy during this.
- I'm pretty certain I shortened my life quite considerably with soldering 2,200 LED posts (4 per LED), not to mention the rest of the components.
- I used a ProtoMat S103 and ProtoLaser S to laser up the boards and do the hole drilling process. My access to this equipment is somewhat limited, and the process is pretty time consuming. Each of the two 9" boards, to laser and drill, takes about 2.5 hours, provided all the equipment functions properly and you can bang everything out quickly. This is the coolest equipment I've ever used:
[ame=http://www.youtube.com/watch?v=bQ_cfgILjJU]alkdflkarowue - YouTube[/ame]
- The end result is NOT waterproof (yet?)
It turns out there is a separation moulded into the housing between the lights that do your brake/running and your turns. That's how it keeps the left/right sides dark while your brake lights are on. This has to be removed, and when you do, it goes clear through the housing. You can see it underneath the bottom of the boards in that picture. To fix this, you have to fill the cavity with some sort of goo; I used windshield adhesive because that's what I had laying around. It's effectiveness is still undetermined because I'm avoiding water at all costs at the moment
after they dried, I put on new rotors and brake pads, then on with the calipers. I then added a caliper decal...which really made the caliper pop nicely. - I need to do my rears still, just ran out of time.
