What compression gauge are you using?
98FWDSM
180
Jul 27, 2003
ok, I am about to do a compression test on my engine and I have never done one before so I obviously have to get a compression gauge. Basically all that I need to know is what range of numbers does it need to have on it. I am guessing that I need one that will read from 0 to 200??? Where did you get your compression gauge at?
Thanks :dsm:
You can just get a compression tester at your local autoparts store. They come as a kit with everything you need (like, gauge, tube to reach down into head, and fitting for different plug sizes). The gauge will hold the highest reading, then there is a pressure release button on the side for your next test.
Here's a pic of a typical tester. Some kits might not have as many pieces.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
