What Cams to get?
neuralracing
770
Jul 16, 2003
San Juan, Puerto Rico, Central America
Here is my mod list and my plans are to go with a B16G or some "bigger than 14B" but very quick spool time turbo. My question is what cams should I get? This is not a daily driver so driveability is a non issue:
AEM EMS (Speed Density) w/ Innovate Wideband and Perrin EBCS Boost Control
Walbro 255lph pump w/ FTS FPR
Dejon Tool 1g-QL Intake
SBR 1G Race FMIC w/Tial BOV
SBR 1G Jpipe for FMIC
FIC 750cc Injectors
SBR Cast DSM Manifold (Ported)
ACT2600 w/ ACT Lightweight Flywheel
EVO3 O2 Housing
3" Turboback
Fluidyne Radiator
HKS 272/272 or you could go with something from Forced Performance but you will have to get dual valve springs to use some of their bigger cams.
Why FP2's with a stock head? Are FP'2 a direct drop in (I can use the same Gears, springs, retainers, valves, etc)?
Will i loose allot of lowend with the FP2's?
I like Low End Torque for coming out of corners on road coarses.
Well, you should probably tell us what you want out of the cams. I'm sure you've done searches on different cam names so you probably already know which cams are known for what, right? If not, you should have, as there is a lot of info on all types of cams here in the forums if you just do a little digging. What have you found out about the cams you're interested in so far? Which cams are you considering and why? Are you worried about passing emissions?
Don't make us figure everything out for you now. With the way you worded your question, all you're going to get is people spitting out cam names and not telling you why they think they're better, which has already happened above. If you really want to find out what cams are best for your setup, you'll have to give us more info on what you want to achieve and why.
I was searching for cams not to long ago and I just called FP to see what they would suggest. I told them that I was planning on sticking with my E316 for a long time and that I would be using my car for HPDE's. I also told them I was looking for a cam that would give me a little more pull everywhere and not sacrifice low end power. They suggested their FP1's for what I was looking for.
I am happy with them but then again all I can compare them to is the stock cams. Personally I notice a little more low end pull in part throttle conditions, and the top end is a little stronger. BUT…these cams did NOT feel like a major improvement. They felt like the cams that the car should have come with from the factory. Just my two cents.
BTW this is at 20psi
Good feedback. You see, this guy stated what he wanted from the cams and what he was going to be using the car for. You can't choose a cam without knowing that. This is the info we need to know.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
