lil corb
- 758
- 7
- Sep 7, 2005
Woodbridge,
Virginia
So this is new to me
I have not seen this before but I am getting water droplets on my filter. There are no leaks coming from above it (water line is capped from Water pipe and plus it would be greenish). The only thing I can think of is that the oil filter is the last thing to get hot thus causing condenstation
I don't know if that makes sense or not WTF
Also I have a slight oil leak where the Filter meets the housing. The filter is on there tight too. I am noticing this more after the car is off right after a drive. No other coolant leaks or overheating issues at all.
I have attached a pic as well.
Any ideas???
Thanks
I don't know if that makes sense or not WTFAlso I have a slight oil leak where the Filter meets the housing. The filter is on there tight too. I am noticing this more after the car is off right after a drive. No other coolant leaks or overheating issues at all.
Any ideas???
Thanks
