2G Weatherstrip Part Numbers Help
Rock2610d
255
4
Jan 22, 2013
Cheyenne, Wyoming
Anyone know the name and or the part number for this weatherstip that goes between the glass and top of door window frame. The window "locks" into it when it is up. Please help I need both sides left drivers side and Right passenger side. Would like OEM but I do not know what it is called or its part number to tell dealers.
I got them from JNZtuning a while back. I don't think they are being made anymore, but here is the info.
Thanks but I am not sure that part number is the one I need. The one you show is item 3 (MB913032) on the below diagram which appears to be under the door?? I pulled the first set of photo I posted as what appeared to be what I needed off the internet. Not sure its the actual part I need or not. I have attached a photo of my car with the piece I need. Not sure why it shows a door with a window frame in it, but my door has no window frame and the piece I need is more like Item 5 in this photo but rubber....but again I am not sure.....my cars door does not look like this. I have a 1995 Eagle Talon TSI AWD.
However this next photo shows what my door looks like but does not show the black rubber piece I need. It shows the interior piece(item 7) which on my car is grayish and plastic looking not a black rubber.
I have attached a Photo of the piece on my car I need. See the black piece that is hanging and the other piece I laid on top of car? That is what I need...
I do not see it. The part I need is attached to the roof not the door. The door glass presses against it when the door is shut.
If I am missing it could someone point it out?
Number 4 comes in two colors, gray or blue. Isn't that part a trim molding? The part I need I thick black rubber.
There is a set of numbers and letters on rubber: 1G24-Z3 L3. Anyone know what they mean?
Based on the picture that you posted, this is the part that you are looking for.
I get all my OEM parts from JNZ tuning. I think that these have been discontinued....as have so many other parts. Almost all of the trim parts are gone. I saw a used pair for sale on Miller import parts (a DSMtuners vendor) they are asking $29.95
