Weak clutch pedal after high revs
awdtalon21
152
Mar 4, 2007
St. Charles, Illinois
I have a 1995 gsx with a act 2100 pp and a 4 puck disk with a stock flywheel, my problem is when im driving and give it full throttle, when i go to shift into the next gear my clutch pedal is only half way up and it feels like it lost pressure. Some times it will go into the gear and sometimes it will grind and not even go into the gear at all. After i pull the pedal up and pump it again it will be fine again, until i do another pull again. The clutch works fine as long as im driving around normally, It only starts to act up after high revs it seams.
The slave and master are not leaking and i have made sure the system is properly bled right. Not sure what to check right now.
