Clutch Pedal
dj_lethrow
137
May 5, 2003
north dakota, North Dakota
Well I'am getting ready to weld my new clutch pedal assembly. I have a few questions. Should there be any play with the new assembly in there from side to side? There is just a little. When I weld should I leave the nut off the end and weld right in there? Also does the pedal need to be compressed like it would be to the floor or up in the position not in use.
Needs to be in the up Position...and as for the nut its your call..the side to side play is ok..
