1Gina2G
- 810
- 2
- May 6, 2011
Beaufort,
South Carolina
okay everyone, I recently decided to take apart the main timing belt, with all the marks lined up, also put the cam gear jamming tool in place. The reason was because of a slightly damaged water pump was a cheap ebay one but also noticed OEM from extremepsi is over $150 so I bought the gates one from them for $40 roughly, specified for years 90-94, also got a new 6 bolt tensioner pulley since I had one from a 7 bolt and it was really dirty/rusty, this is a 6 bolt block to clarify.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
is it possible the water pumps getting in the way? I have the special tool for the tension pulley, and to make room gets in the way to tighten the center bolt, or the water pump is in the way. Unfortunatley I threw away my old pump since I did not see a reason to keep it but I think this new one may be a bit more extended then the last one I had. never had this problem doing the timing with the old pump, not sure what the problem is.
