Wastegate travel question
Birdoprey
69
Jun 17, 2005
Snyder, Texas
I'm doing some porting on a 16G turbo that i'm about to install on my 91 Eclipse. I've ported the housing behind the wastegate flapper so that it can achieve a full 90deg.
The problem that i see is that the stk wastegate does not have enough travel to allow the flapper to go much past 45deg. I tried using a pressure pump on the wastegate to check the travel and it will not go any more.
I've done a search and only come up with how to do the porting to achieve the full travel, but nothing on what allows the gate to open enough.
Am i missing something? What do i do???
Your not missing anything, as you discovered the WGA can only move the wastegate arm so far. That's how it works.
Steve
Then why port so that the arm can achieve a full 90 deg if the wastegate can't travel that much? In my search i found countless posts and pic's about doing this, but nothing about the wastegate not having enough travel.
Is there a different wastegate option?
