wastegate solenoid plug (help)
89gt02
30
Nov 29, 2012
Robbins, North Carolina
Hey guys ive searched and searched for the plugin for the wastegate solenoid plugin.
I just got a new wastegate solenoid because the car didn't have one on it.
i have all the vaccum lines hooked up.
I cannot find the plugin for it and I've looked where it is supposed to be but its not there.
the only thing that looks like it is the plugin for the coolant reservoir and it actually p
lugs into it. I know that cant work tho.
Please help if anyone knows what it looks like and where it should be coming from.
I have a 97 gst with fmic and injen hard pipe kit.
????:confused: What are you talking about? Can you please post a picture of what you want or need?
I think you might be confusing something or using the wrong name for it!
Are you talking about the boost control solenoid maybe?
The low coolant level connector is not the same as the solenoid connector, so if you found a plug that works with the BCS then that's the one you need.
I cant find the wire that plugs to it does anyone know what it looks like
Or the color of the wires and pluggin?
Ok by any chance you know the colors of the wires in case some idiot cut it or something?
