Wastegate Solenoid
Generation1JeY
547
Aug 5, 2004
San Diego, California
i was wondering if u always need some kind of solenoid to control the wastegate. I know theres the one that comes stock, but my previous owner installed an electronic boost controller and threw away the stock BCS and then when he sold me the car took the viewing screen for the electronic boost controller so there was nothing controlling the wastegate. I unplugged the boost controller and connected the wastegate actuator to the boost hose hoping that direct boost pressure would make the wastegate do its job but it still doesnt open.
Do u always just need some type of controller whether that is the stock BCS or a mechanical boost controller or electronic boost controller to connect to the wastegate actuator?
No. You can run a vacuum line from a boost source directly to the WG actuator. This will provide the lowest boost setting. If your WG isn't opening, check the actuator arm and related parts and make sure everything's connected and working properly.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
