Wastegate Solenoid Restrictor Removal...HELP!!!
Turbo_Frog
680
Oct 6, 2003
I removed the restrictor from the WGS this morning but I'm having a problem. There are two hoses that run to the WGS. Following the vfaq instructions it says that the hose with the metal clip goes at the bottom. Well that particular hose was originally on top for me and the hose that goes to the bottom opening is not connected to anything. Is this normal???? Should I just move the hose with the clip to the bottom and the other hose to the top not connected to anything??? Need Help!!! :thumb:
Mine was backwards as well... the intake to the BCS goes on the T on the BCS and the other line goes to the T from the compresser outlet to the WG Actuator. At least that is how mine is done. I'm just waiting on my MBC to get here along with my gauges and new turbo... :)
