wastegate solenoid restrictor removal ?
95talon07
47
Mar 1, 2007
chardon, Ohio
ok so i did the removal, and i was starting to put it all back togather. And i am missing the upper vacuum hose that conects into the solenoid. It just up and ran away i swear to God. What does the other end of that vacuum hose connect to? i am not talking about the hose i took the restrictor out of ...the other one. Thank you to anyone who answers
:talon:
I can't remember which hose has the restrictor in it, but I can tell you that one of the hoses goes to the wastegate right beside the turbo, and the other one goes to the bottom of intake pipe, it's probably that one, as it would be hard to see.. it's probably just hanging straight down under there.
I read the write up on removing that and I'm thinking of doing it next time I'm under their let us know if you get any results from it.
