Was planning Megan exhaust w EVO III 16g, wich manifold?
andakanda
142
Nov 11, 2009
Bergen, Europe
Had planned a setup using
Megan 3" exhaust system gsx EXTREME PSI : Your #1 Source for In Stock Performance Parts - Megan Racing 3" Cat Back Exhaust System: Mitsubishi Eclipse 95-99 AWD
Megan 3" downpipe gsx EXTREME PSI : Your #1 Source for In Stock Performance Parts - Megan Racing 3" Downpipe: Mitsubishi Eclipse 95-99 AWD
Megan racing ss o2 outlet EXTREME PSI : Your #1 Source for In Stock Performance Parts - Megan Racing SS Turbo Outlet(O2) Housing: Mitsubishi Eclipse 90-99
with the EVO III turbo
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Mitsubishi TD05H "EVO III Big" 16G
Now im looking for a new manifold , stainless steel type. Been looking abit and there are several options
Do you guys have any experience with this combination , if so , can you recommend a good one? Turbo manifold
I would say FP Race manifold as well if you want some good flow. If you must have a tubular design which are more prone to cracking then you can't go wrong with Punishment Racing.
Port your 2g exhaust manifold and be done with it, you'll be saving yourself about $275 in the cost of parts and however much else it would cost you to replace your melted radiator fans. The FP exhaust manifold is an amazing piece but for your application you won't have any noticable gains, save that money and spend it on fuel injectors/fuel pump and a way to control your fuel since you'll be running that bigger turbo.
Running that bigger turbo and 3" exhaust from the turbo back expect to see boost creep too, you might think about porting the turbo NOW to fix the issue before you even have it?
Porting your 16g
Porting your 2g Exhaust Manifold
:dsm:
I agree, unless going to a large turbo that will take advantage of a SS tubular manifold, just stick with your 2g ported or a good 1g mani ported but can be hard to find without cracks these days. The ebay OBX mani's have had some good success. A lot of people buy the cheap ebay mani's then reweld it so it wont crack. Still way cheaper.
