evo III exhaust manifold
4g63eagle
151
Nov 3, 2009
arozonoo, Africa
i was looking into buying a evo manifold and i need to know if i can bolt it up to my 13b "auto" i wont be using this turbo for more then a month but i wanted to buy a new manifold now my stock one is horrible looking :p
I thought 1G auto's came with a 13g?:confused:
Anyways,the Evo3 Exhaust manifold is designed to match the 7cm^2 turbine housing that the Evo3 16g uses..the 13g has a 6cm^2 hotside but Since you're only going to be using the turbo for a month, I'd say go for it! and yes, it will bolt up to your turbo.
thanks yea its a 13g:aha: i typed it in wrong yea i just need it to bolt up for a month or so till the holidays get over thanks again
Actually, the 13g has a 5cm turbine inlet and will not work with the Evo3 manifold. I suppose you maybe could make some adapter plate, but definitely not worth the hassle. Unfortunately, swapping a 6/7cm turbine housing IS NOT an option due to smaller turbine wheel that the 13g has.
If you're getting a good deal on the manifold, and just wait to install it until you have a matching turbo for it.
yea im gonna make a paperweight :p out of my old turbo im just gonna use it until the end of the month so i wouldnt put any time into making a adapter plate
or changing the housing thanks for the info....i looked into the 100 diff. tube manifolds and they just look like thin wall tube and a blind welder some people say they use them with good results and some say horrible things so i figure i will just buy a evo manifold unless anyone has any other idea's for a good exhaust man.?
